Forums >> Revit Systems >> Technical Support >> draw conduits/pipes in Revit Architecture
Wed, Feb 29, 2012 at 1:08:21 PM | draw conduits/pipes in Revit Architecture
kenmotsu
Is there a command to draw either conduits or small pipe lines in Architecture?
Wed, Feb 29, 2012 at 1:24:43 PM | draw conduits/pipes in Revit Architecture
No.  You would have to use MEP, create a family, or use linework.
Wed, Feb 29, 2012 at 1:28:39 PM | draw conduits/pipes in Revit Architecture
kenmotsu
Thank you.
I have tried making pipelines, but I could only use one size diameter in 2 dimension. Could you direct me to a few "help menu" for creating this kind of interactive families?
Wed, Feb 29, 2012 at 1:52:11 PM | draw conduits/pipes in Revit Architecture
Why not start by using one of the pipes in the downloads area.  The one is easily sized.
Parallel Pipes and conduits
Wed, Feb 29, 2012 at 3:48:12 PM
Can we convert lines to pipes? (Revit MEP)
Tue, Aug 28, 2007 at 9:26:18 AM
can't "reach" pipes (revit MEP)
Wed, Dec 21, 2011 at 6:24:35 PM
Using tools in the Systems tab - Revit Architecture 2013
Wed, Sep 19, 2012 at 4:21:08 PM
Complex Conduits
Mon, May 9, 2011 at 6:00:40 PM
Page generation time: 1.3762
