17 Users Online (15 Members):
Forums >> Workflow & Implementation >> API & Third Party Apps >> 3D PDF inclusive material textures
7 Posts No Rating |
Hello all,
I'm trying to create a 3d PDF file from a Revit building. I'm using Bentley I-model plug-inn and the Bentley I viewer. I get a nice 3D pdf, but only with some basic colors. Is there a way to create one with more detailed materials or textures?
8 Posts No Rating |
I have tried the PDF revit from Tetra 4D and it will give you the textures! You can also choose to not have textures if you are doing a quick model. I suggest to check out thier facebook site and download the trial. works well and they just announced the release for Monday the 5th. 2012. Check it out!
http://www.facebook.com/3DPDF#!/3DPDF?sk=app_153284594738391
www.tetra4d.com
Mike
7 Posts No Rating |
Thanks for your reaction.
I tried Tetra trial version, but the Revit pluginn doesn't work. I can try to re-install it.
Anyone an other solution to get textures in a 3D pdf?
scrapbooking |
8 Posts No Rating |
Tetra 4d has recently released the new version of 3D PDF for Revit 2014 which includes updates for more realistic textures and materials. You can create 3D PDFs directly from the Revit Add-Ins menu, where you can accurately export all 3D model elements including structure, color and texture to 3D PDF. Hope this helps!
Hayley
8 Posts No Rating |
Try 3D PDF Converter for Revit from 3DA Systems. The software handles and supports textures from Revit 2012/2013/2014.
http://www.3dasystems.com/products/3d-pdf-converter-revit/why-3d-pdf/
or Autodesk Exchange Store:
http://apps.exchange.autodesk.com/RVT/en/Detail/Index?id=appstore.exchange.autodesk.com%3a3dpdfconverterforrevit14%3aen
30 Day trial avaliable.
Revit render textures - any good resources on the web? |
Thu, Dec 16, 2010 at 10:54:15 AM
Printing PDF Line Drawing - Wont show surface textures |
Tue, Oct 23, 2012 at 9:24:39 AM
Revit 2013 textures not printing to pdf or paper |
Mon, Feb 3, 2014 at 2:15:52 PM
how do I fix a material |
Tue, Apr 15, 2008 at 10:47:25 AM
free hi res textures |
Mon, Apr 13, 2009 at 2:47:29 AM
