Forums >> Revit Building >> Technical Support >> linking objects
Tue, Feb 28, 2012 at 9:04:33 AM | linking objects
sgray05
I realize this may be a real basic function.
How do I lock an object or element to another. for instance locking a millwork to a wall so that they move together. or the backsplash to the counter.
Thanks
Tue, Feb 28, 2012 at 9:37:12 AM | linking objects
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Use the align tool then when the "lock symbol" pops up click on it to lock it.  Also under the properties there is a check box "Moves With Near By Elements" that you can check that before you place the millwork on a wall and it will follow the wall as you move it.
linking ole objects in Revit project
Mon, Jul 25, 2005 at 8:47:41 AM
Linking models with multiple sites
Wed, Dec 6, 2017 at 9:43:09 AM
Odd behavior when Linking AutoCAD
Thu, May 25, 2017 at 11:45:05 AM
Copy/Monitor and IFC
Thu, Jun 25, 2015 at 3:05:37 PM
Converting AutoCAD ACIS Objects (3D Solid) to Polymesh Objects
Fri, Oct 12, 2012 at 7:31:58 AM
Page generation time: 0.2301
