Forums >> Revit Building >> Technical Support >> can't group objects
Sun, Feb 26, 2012 at 4:52:06 AM | can't group objects
yosab
good day every one,
we are working on a hotel project, i am trying to group several items in on room so i can make instance of it with the ability to change in the future,
the problem is, when I try to apply the group command on the selected items (walls, families) it doesn't work, items remain individually selected but with a group tag on them, and when you press the group tag, it simply disappear,
what's wrong ?
thx in advance.
Fri, Jul 6, 2012 at 12:22:47 AM | can't group objects
raja15
We had a similar issue with a unit development we were doing in Revit 2012.
However the group tag which appeared (when selecting one element within a model group as shown in your attached screenshot) was specifically to "Exclude element from the group", not edit the group as such.
Perhaps try drawing a box select around that bathroom/ensuite area, then filter and un-tick any additional items (other than the model group) and edit group from there?
can't make change to group with more than one instance [ 1 2 ]
Sun, May 21, 2017 at 1:30:17 AM
16
INSERTED GROUP - COPIED GROUP - DIFFERENT RESULT [ 1 2 ]
Wed, Nov 23, 2016 at 3:27:29 PM
15
CAN'T SELECT GROUP
Sun, Nov 25, 2012 at 12:33:43 PM
edit group panel missing
Tue, Jan 17, 2012 at 2:54:43 AM
12
Grouping Line-based Families
Mon, Oct 30, 2006 at 12:00:45 PM
Page generation time: 0.7308
