Forums >> Revit Building >> Technical Support >> Duplicating floors and ceilings question
Fri, Feb 24, 2012 at 11:43:13 AM | Duplicating floors and ceilings question
COUGARBRENT
When ever i want to create a new floor or ceiling i select a current one, duplicate it rename it, and edit the newly created floor.  The problem is when I select the floor or ceiling and go into the edit type and change the finish surface pattern it applies the new surface pattern to all of my other floors and ceilings even though they are named differently.  Im sure its an easy fix but Im stumped.  Help please.
thanks
BL
Fri, Feb 24, 2012 at 11:44:55 AM | Duplicating floors and ceilings question
This is not a floor type property - it is a material property.  Add a different material to your new floor type.
Fri, Feb 24, 2012 at 12:06:41 PM | Duplicating floors and ceilings question
COUGARBRENT
THANKS
Revit export/import to IFC - ceilings and floors (ifccovering)
Mon, Jul 28, 2014 at 3:22:58 PM
Light fixture and ceiling problems
Tue, Jul 29, 2008 at 10:35:07 AM
Room tag
Mon, Sep 14, 2015 at 7:10:57 PM
Ceilings not appearing
Wed, Nov 4, 2015 at 4:48:40 PM
Complex ceilings
Thu, Oct 8, 2015 at 1:02:54 PM
Page generation time: 3.0270
