10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> truncated autocad dwg
38 Posts No Rating |
REvit 2012
I am getting this error message when inserting a cad link.
geometry in dwg file has extents greater than 1E9 in Autocad units. Data exceeding that range will be truncated.
How can I fix this?
Your CAD file is too large. Usually the problem is origin but also if they linked in another file. Best advice is to edit the CAD file using WBLOCK with a closer origin.
thank you-relocated 0,0 and wblocked.
.dwg import problem |
Tue, Sep 6, 2011 at 7:48:54 AM
revit dwg into autocad |
Tue, Apr 27, 2010 at 11:13:41 AM
having trouble creating a truncated cylinder |
Wed, May 9, 2007 at 4:11:33 PM
AutoCAD DWG Blocks |
Sun, May 9, 2010 at 10:43:13 AM
Sheet DWG exports appeat PINK in autocad |
Wed, Apr 10, 2013 at 7:54:45 AM
