Forums >> General Discussion >> Revit Project Management >> Revit 2012
Fri, Feb 24, 2012 at 9:35:10 AM | Revit 2012
Smytman
My firm is now using Revit 2012. Is there a way is link components? Meaning that once I pull several components(detail and model) out the library and place them in a template, if I decide to modify one of them it will also modify the same one in the library.
Fri, Feb 24, 2012 at 10:10:50 AM | Revit 2012
Once the item is in the template, it is stand-alone.  It does remember where it came from but that is all.  Therefore, you have to update both your library and any elements in any files you have, including templates.
This does create some maintenance issues.  When you update year to year and if you just update your template, its components are updated but still pathed to your old library location.  (We maintain a new library for each version.)  So if you open a family for editing from a template that was updated from 2011, and save it, it will go back to your 2011 library even though it is now a 2012 family.  You have to do a save as into your new library location.
"auto" open in Revit 2012, when you have both 2012 and 2013
Sun, Jul 12, 2015 at 4:52:17 PM
Revit 2012 crashes at splash screen HELP!!!
Fri, May 17, 2013 at 1:13:24 PM
Revit 2012 Crashes Random but everyday [ 1 2 ]
Wed, Feb 29, 2012 at 1:15:57 PM
15
Flat roof with sloped edges! HELP! Revit 2012!
Wed, Jul 11, 2012 at 6:34:15 AM
12
Parameter Jerk 2012 Released
Mon, Sep 12, 2011 at 10:47:07 AM
Page generation time: 1.7381
