Forums >> Revit Building >> Technical Support >> Export 3D view to new revit file
Fri, Feb 24, 2012 at 8:49:23 AM | Export 3D view to new revit file
stealthnyc
4.5 Stars: 2 Votes
I'm using revit 2012.  I would like to export all of my curtainwalls, which i have isolated to a particular workset, to a new Revit file where i can play around with them without messing up my original project.  I can't seem to find a way to "Save to New File" like you can for a detail or drafting view.  I would prefer to export my isolated view into a fresh new project instead of saving a new file and deleting out everything else.  Anyway to do this?  Thanks.
Fri, Feb 24, 2012 at 9:05:23 AM | Export 3D view to new revit file
Just have both projects open then copy to clipboard and paste in your new file.
Fri, Feb 24, 2012 at 9:19:03 AM | Export 3D view to new revit file
TKennedy
4 Stars: 8 Votes
Another way to go is to group your curtainwalls (and/or anything else you'd like in another project), then save the group as a project. Right click on the group in the project browser, save group.
Fri, Feb 24, 2012 at 10:40:44 AM | Export 3D view to new revit file
stealthnyc
4.5 Stars: 2 Votes
Thanks.  I tried the copy/paste but it took 20 minutes to do the selection of the entire exterior skin and paste into another project.  And not everything came in. The group seems to be the way to go.  Thanks!
Fri, Feb 24, 2012 at 10:47:54 AM | Export 3D view to new revit file
20 minutes?  I thought you said they were on an isolated workset.  I could do this is less than 3 minutes. ... and everything would be there.  Just turn all worksets off in 3D except for your "particular workset".  Window and copy to clipboard.
No reason why something didn't transfer.
Fri, Feb 24, 2012 at 11:36:49 AM | Export 3D view to new revit file
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
I'd use design options. keep the original as the primary and mess around with other options. that way if you come up with something better its live in your project enviroment.
export dwg including a linked revit file
Tue, Jul 31, 2012 at 12:30:21 PM
REVIT 2013 - Export DWG Layers Text File Location
Fri, Aug 3, 2018 at 4:44:52 PM
3d view export to AUTOCAD
Thu, May 28, 2009 at 12:00:59 PM
Revit 2014 Export Sheets or Save to new file
Thu, Jan 28, 2016 at 11:21:21 AM
3D DWF export in Revit 2009 does not export identity data
Thu, Nov 19, 2009 at 12:01:43 PM
Page generation time: 1.8673
