22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> Partial height Ceramic Tile
50 Posts No Rating |
I am trying to create a bathroom wall that has half height ceramic tile so the bottom half is tile up to the wainscoating. I tried to do this with the splitting the regions, but it seems I need to add a material to the top also to keep the wall coplaner. is there a simple way to do this? Will I need to create a compound wall?
For tiled walls, full or partial height, we add a thin wall against the face of the standard wall (model like you build). After placing, just join the wwo walls and doors / windows will cut both walls.
Ceramic Tile Flooring |
Wed, Jan 2, 2008 at 9:03:02 AM
Can Door/Window cut through multiple walls |
Wed, May 26, 2010 at 10:06:37 AM
Tile Pattern Height |
Mon, Oct 9, 2006 at 2:36:02 PM
Help of Hatch Tile in a Ceramic Material |
Fri, Aug 31, 2018 at 10:15:19 AM
Door not cutting joined wall |
Thu, Nov 7, 2013 at 5:58:37 PM
