Forums >> Revit Building >> Technical Support >> Creating a topography from 3D CAD survey import
Thu, Feb 23, 2012 at 5:17:45 AM | Creating a topography from 3D CAD survey import
chidave
I am a new Revit user and have been having a few problems with importing a 3D dwg and converting it to a topography in Revit.
My dwg been produced by inserting a block (two lines to create a cross, with the insetion point at midpoint) and giving it a Z value. Please find attached drawing.
I imagine that revit cannot read a block insertion point as information to create a topography or can it and im just doing it wrong?
What do I have to do to make this information in the dwg intelligent so it can create a topography. Would it be easier to create the topography by placing a point?
Many thanks for your help
Dave
Thu, Feb 23, 2012 at 7:53:01 AM | Creating a topography from 3D CAD survey import
You need a points file.  There does not appear to be valid 3D points in here.  Yes, the + blocks are at 3D levels but those are linework, not points.
matching contour lines from civil CAD when creating Topography (2019)
Fri, Dec 4, 2020 at 2:09:46 PM
Importing 3D Cad topography problems
Tue, Oct 13, 2009 at 5:55:51 AM
Survey CAD file with large coordinates
Wed, Sep 21, 2016 at 10:36:25 AM
sloped Topography
Sun, Oct 22, 2006 at 9:57:25 AM
topography not being generated at the correct level
Thu, Oct 12, 2017 at 8:01:15 AM
Page generation time: 0.3797
