Forums >> Revit Building >> Technical Support >> View Name showing up in Elevation Tag
Wed, Feb 22, 2012 at 10:00:44 AM | View Name showing up in Elevation Tag
sgray05
The View name is showing up in my interior elevations tag and I can't seem to get rid of it. Based on my Tutorial book I need to go into Additional Settings/Elevation Tags and change the Elevation Mark to Elevation Mark Body_Circle : Detail Number.    But this isn't an option.
My only options showing up are the following 4
Elevation MarkCircle - Upgrade; Elevation Mark Circle - Upgrade : 1/2" Circle; Elevation Mark Square -Upgrade; Elevation Mark Square - Upgrade : 1/2" Square.
Any Help? THanks
Sat, Feb 25, 2012 at 4:21:24 PM | View Name showing up in Elevation Tag
btag
I'm in exactly the same position - I have no other options apart from the 4 specified by sgray. Help would be greatly appreciated.
Tue, Feb 28, 2012 at 9:10:47 AM | View Name showing up in Elevation Tag
sgray05
btag,
I somehow got it to work. (don't know if you have figured it out yet) I believe I inserted the interior elevation tag from the library and this then gave me additional options in the settings.
Give it a try..
Wed, Feb 29, 2012 at 6:53:36 PM | View Name showing up in Elevation Tag
btag
Nice work. I tried that out, and thankfully it fixed me as well!
One elevation tag / two pointer directions / one drafting view
Wed, Dec 18, 2013 at 8:58:33 AM
Interior Elevation Tag missing from drop down
Wed, Aug 18, 2010 at 4:28:45 AM
My dependant elevation view tag will not show up in my dependant plan view
Tue, Jan 8, 2008 at 11:47:57 AM
Wed, Dec 19, 2012 at 2:25:25 PM
Hiding View Name in Elevation View Tags
Fri, Jan 21, 2011 at 6:47:39 PM
Page generation time: 0.8495
