12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> Looking for a source for png images to create blue painted cmu rendered image
Basically, the cmu material in Revit is either white or grey. I need to render a dark blue painted cmu wall. Any suggestions on how to find or create that? Thanks.
I did finally look further down in the material file and there was a masonry, blue glazed block wall image that will work in this case. But what if my client wants another color wall? Without a new png image file to insert, how do I do this?
Then you copy the jpg file and edit the color using a different program and create a new material in Revit for it.
another source for textures and color, www.cgtextures.com
1 Posts No Rating |
The downloaded black Corbusier Loungue renders white. After changing the "crocodile" material (listed twice), it renders white. What is wrong? (Chaise_Loungue_-_Le_Corbusier_-_with_parametric_oscillation_3304.rfa)
Border printed around .png inserted images |
Mon, Aug 22, 2011 at 1:57:49 PM
painted cmu wall.. |
Thu, Nov 14, 2013 at 11:16:49 AM
Rendered Image Colour Problem |
Thu, Jun 13, 2013 at 11:23:05 AM
Rendering Tab |
Tue, Sep 9, 2008 at 3:05:16 PM
CMU in a cut section |
Mon, May 25, 2009 at 12:50:44 PM
