Forums >> Community >> Newbies >> Disappearing Pipes
Wed, Feb 22, 2012 at 7:43:54 AM | Disappearing Pipes
MaddMart
I have drawn some pipework in Revit MEP and it shows up, as it should, in all views. But when I link it to a boiler and assign a system to it the pipework disappears in all but the 3D views. The boiler is still visible. I've tried using filters but that doesn't seem to work.
Wed, Feb 22, 2012 at 9:56:41 AM | Disappearing Pipes
romzek54
2.5 Stars: 3 Votes
have you tried alt f4?
Wed, Feb 22, 2012 at 11:53:09 AM | Disappearing Pipes
jterrell
3 Stars: 5 Votes
check your filters and make sure the hydronic filter is visible
Thu, Feb 23, 2012 at 2:03:00 AM | Disappearing Pipes
MaddMart
Thanks jterrell, I tried that but still no good. The filters I have on are 'Domestic Cold Water' & 'Domestic Hot Water which are the systems the pipes are using when I connect them to the boiler.
Thu, Feb 23, 2012 at 9:33:59 AM | Disappearing Pipes
jlights
3 Stars: 2 Votes
We had some disappearing ductwork a while ago, and it turned out that the duct was assigned to "other". Check the connector in the boiler and make sure it is set to either Global (which will cause it to inherit the system type to which it is connected) or something more specific (Domestic hot water, or whatever the system type is that the boiler is part of). HTH.
jlights
Tue, Feb 28, 2012 at 5:00:52 AM | Disappearing Pipes
MaddMart
Thanks jlights, I had the connectors set to Domestic Hot Water & Domestic Cold Water. I've cracked it now, although I had DHW and DCW in the filters list, it was only when I clicked the visibilty on the 'Domestic' filter that the other two systems became visible. Strange!
Duo pipes - Twin pipes for central heating
Wed, Jan 16, 2019 at 3:48:53 PM
REVIT MEP 2012 Demo Phasing Disconnecting Pipes
Wed, Jul 18, 2012 at 12:20:02 PM
Pipes display as solid in section
Thu, Apr 25, 2013 at 9:27:41 AM
rain water pipes
Fri, Mar 9, 2007 at 1:06:21 PM
Connecting 3 Pipes
Mon, Jun 28, 2010 at 11:25:05 AM
Page generation time: 0.3301
