Forums >> Revit Building >> Technical Support >> EXPORT TO DWG - Problems
Wed, Feb 22, 2012 at 1:56:36 AM | EXPORT TO DWG - Problems
CRB14
Hi there,
I'm using Revit 2012 and trying to export my project as a DWG. Each time I've tried, it's saved each view as a separate DWG file....is there an easy way around this? Any help much appreciated....
Thank you!
Wed, Feb 22, 2012 at 6:50:28 AM | EXPORT TO DWG - Problems
W#hen you export, uncheck the box "xref views on sheets" when on the file naming tab.
Wed, Feb 22, 2012 at 1:56:28 PM | EXPORT TO DWG - Problems
CRB14
Hey there - appreciate your reply, I unchecked the box yet it still exported each view individually....anymore ideas? Thank you!
Wed, Feb 22, 2012 at 2:07:22 PM | EXPORT TO DWG - Problems
Sorry, but I have yet to see it do that so I think you have erred.  Maybe those views are left over from a previous try.  Look at your time/date for the file.
Wed, Feb 22, 2012 at 2:12:49 PM | EXPORT TO DWG - Problems
CRB14
Hey - yeah checked all the times/dates etc.....I've attached a screen shot (But they often don't attach so might not show)...I've fiddled round but keeps seeming to create a heap of different files....not sure what else to do : (
Wed, Feb 22, 2012 at 2:28:53 PM | EXPORT TO DWG - Problems
I think you may have not cleared your selection set and you have views as well as sheets selected for export.
Do one sheet into a clean directory and verify that you have done it correctly.  If that doesn't give you just 2 files - dwg & pcp & you jpeg's then you may have a corrupt program.
Export 3d DWG issues
Fri, Jun 28, 2013 at 8:27:02 AM
Revit Export to AutoCAD DXF/DWG problems with linked files
Wed, Aug 27, 2008 at 9:42:43 AM
Revit Export to 3D .DWG still will not export Ceiling Grid Hatches?
Wed, Feb 11, 2009 at 4:42:25 PM
Export Linework colors to DWG
Wed, Sep 14, 2016 at 12:04:12 AM
Some problems with the export from rvt to dwg
Thu, Jan 14, 2010 at 3:10:42 AM
Page generation time: 2.1810
