Forums >> Revit Building >> Technical Support >> 2011 creating mass
Tue, Feb 21, 2012 at 4:47:12 PM | 2011 creating mass
aaronkennedy
So I use create mass very rarely.  What happened?  I used to be able to build a timber truss out of one extrusion and now I need to use a combination of masses and voids?  Is this easier in the long run?  I had to get online to find out how to make all that stuff again.
Tue, Feb 21, 2012 at 5:11:17 PM | 2011 creating mass
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Maybe use an in-place family with a single extrusion like you used to ?
Wed, Feb 22, 2012 at 9:05:58 AM | 2011 creating mass
aaronkennedy
I did but it is just not as easy as it used to be.
Wed, Feb 22, 2012 at 9:34:16 AM | 2011 creating mass
Are you using conceptual mass rather than just an in-place family?  I don't see any changes really in 12 in the in-place modeling.
Wed, Feb 22, 2012 at 9:59:37 AM | 2011 creating mass
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Massing definitely changed. There is now a 'conceptual mass' (created externally from the mass template file, allowing parameters etc) , an 'in-place mass' and an 'in-place family'. They all have solid and void elements that resolve each other.
The in-place families (as well as external families) still use extrude, blend, revolve, sweep and sweep blend.
Massing uses 'create form' to convert 2d geometry into solid and void objects that can be further manipulated by face or by edge.
Conceptual Massing can take advantage of 'parameters' or variables because it is an external file that gets loaded into the project.
Hope this info helps . . .
Edited on: Wed, Feb 22, 2012 at 10:51:27 AM
Wed, Feb 22, 2012 at 10:26:16 AM | 2011 creating mass
aaronkennedy
Hmm, (dashes off to Revit)  thanks,
Wed, Feb 22, 2012 at 10:35:02 AM | 2011 creating mass
aaronkennedy
Aaaaaand I'm back.  In-place families are where it is at.  Thanks everyone.  I was using conceptual mass instead of in-place families.  I feel like a dope.
Thanks again!
AAron
Autocad 2011 Solid To Revit 2011 Mass floor error
Mon, Feb 28, 2011 at 7:20:10 AM
Sphere Mass - Changing the mass into a roof
Tue, Apr 16, 2013 at 8:25:38 AM
the mass is no longer transparent in 2011?
Sat, Oct 2, 2010 at 8:54:40 AM
Mass Floors not all showing up - some missing
Wed, Apr 11, 2012 at 4:44:46 AM
how do a SWEEP mass and DONUT ,etc in revit 2011?
Thu, Dec 9, 2010 at 1:21:36 PM
Page generation time: 2.0244
