Forums >> Revit Building >> Technical Support >> saving families in a project
Tue, Feb 21, 2012 at 1:43:51 PM | saving families in a project
Warchitect
4 Stars: 5 Votes
SO Im asking a dumb question I think, but here goes.
When you load a library family into a projct, in my case a titleblock, but it could as well be a window, then you create, in the properties editor, another type...does that update the types in the original file sitting in the library folder? or just the family as it sits in the project?
I updated my title block in the original file, but a project that had it loaded from before still shows the old titleblock, and if I select that t-block in the project, click edit family, update titleblock...that does NOT update the original file?
Tue, Feb 21, 2012 at 1:47:50 PM | saving families in a project
Once a family is loaded, all changes made from "edit family in the project" are only in that project.  You would have to edit the family from the project and save to your library if you want those changes there.
And by the way.....
The path of the family you edit from withing a project may not be the same as your current library.  Just a warning to make sure you save in the right place.
Edited on: Tue, Feb 21, 2012 at 1:49:14 PM
Tue, Feb 21, 2012 at 2:41:58 PM | saving families in a project
Warchitect
4 Stars: 5 Votes
thanks hub
Saving all families from a project
Mon, Nov 18, 2013 at 1:23:16 PM
Exporting/saving Families
Thu, Apr 6, 2006 at 5:49:14 PM
Saving a family fom project to family editor
Fri, Sep 17, 2004 at 6:39:40 PM
Extracting families from a file for future use in other files
Tue, Mar 22, 2011 at 8:56:36 AM
Thumbnails of families in properties browser
Tue, Jan 7, 2014 at 7:54:37 AM
Page generation time: 2.6825
