25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> Showing objects in higher levels in hidden linetype
1 Posts No Rating |
Hi
I'm using Revit Architecture 2012 and I want to know if this is possible.
I have an Arc as a steel structural member and it starts from ground floor and reaches its peak 3 levels higher.
In ground floor Revit cuts this element near it's base and that is fine, but...
is there a way that I can show the rest of the arc that is higher than ground floor cut level, in a hidden line style?
FYI.. The arc is a custom made structural family.
Thanks
90 Posts No Rating |
Same question here
Do you wanna SKYPE Revit? Its quicker  |
Read this in your HELP: Changing Line Styles for a View Underlay Underlay is the level above.
Hidden Objects in Sheet views |
Fri, Jun 13, 2008 at 12:10:26 PM
LINESTYLE OF HIDDEN STEEL COLUMNS |
Mon, Jan 17, 2011 at 5:25:38 AM
Levels hidden in elevation |
Thu, Aug 18, 2011 at 2:29:17 PM
objects in view on sheet set not showing up in PDF |
Wed, Jul 10, 2013 at 7:00:02 AM
How to add new linetype to family |
Fri, Jan 3, 2014 at 10:01:49 AM
