Forums >> Revit Building >> Technical Support >> Window - wall intersection
Mon, Feb 20, 2012 at 6:37:22 AM | Window - wall intersection
Vpokunoff
Hi,
I have a small problem with my wall or window. When I slide my window close to the wall ( Value 0 ) somekind of artifact appears.
Im guessing it has something to do with wall wrapping.
My walls cut pattern is set to solid fill black and it appears on medium and fine level.
Regards,
Poku
Mon, Feb 20, 2012 at 7:43:34 AM | Window - wall intersection
I don't think we have enough information to help you.
Mon, Feb 20, 2012 at 7:59:29 AM | Window - wall intersection
Vpokunoff
I have attached 2 pictures. Maybe this will explain it better
Im not able to find what is causing this.
Mon, Feb 20, 2012 at 8:49:32 AM | Window - wall intersection
You want us to guess at your wall structure and your window?  Just too many things to guess.
Placing window at intersection of 2 precast concrete panels
Sat, Jan 5, 2008 at 7:57:00 AM
Dimensioning to a "Point" at wall intersection in 2008
Wed, Jan 30, 2008 at 9:41:11 AM
Wall intersection issue
Thu, Nov 26, 2015 at 9:26:18 AM
problem with wall intersection
Thu, Sep 7, 2006 at 12:18:32 AM
Window at the Seam of a Double Curved Wall
Mon, Jan 28, 2008 at 11:07:42 AM
Page generation time: 0.6590
