Forums >> Revit Building >> Technical Support >> STAIRS - Width problem - "see VIDEO"
Mon, Feb 20, 2012 at 2:17:40 AM | STAIRS - Width problem - "20sec. VIDEO"
zuzullo
http://content.screencast.com/users/zuzullo/folders/Jing/media/071b524a-7792-4f75-91bf-e8fc1d6ac1f0/2012-02-20_1308.png
The stairs cannot be 800mm. Why?
If I try to change it manually it gives the same error:
Edited on: Mon, Feb 20, 2012 at 6:09:21 AM
Do you wanna SKYPE Revit? Its quicker Smile
Tue, Feb 21, 2012 at 12:47:07 AM | STAIRS - Width problem - "see VIDEO"
Warchitect
4 Stars: 5 Votes
Try making the steps outside the model and move it into the right place. sometimes that hels get things into shape. also, have you tried 799 or 801 mm? is it still a problem? if so, it has something to do with the way your trying to make the 800mm width. (something the computer uses to make the stepped extrusion gets messed up) (this happens to me somtimes when I try to make things the wrong way using the extrusion tools...) in the one video I saw you move the line towards the center, maybe try to make it wider from the outside. lastly, try to make it in two stairs sets...maybe you'll have an easier time.
Looking for a short video to show executive team the "I" in BIM
Fri, May 2, 2014 at 2:23:58 PM
Calcualted Value in Schedule Problem
Fri, Feb 19, 2010 at 1:56:28 PM
Room Names is Length x Width
Thu, May 1, 2008 at 12:13:53 PM
non typical stairs
Wed, Jul 16, 2008 at 1:03:16 PM
Stairs in RCPs
Tue, May 26, 2009 at 9:14:41 AM
Page generation time: 0.9779
