Forums >> Revit Building >> Technical Support >> Sections lines not visible in certain plan views.
Wed, Dec 14, 2005 at 11:02:53 PM | Sections lines not visible in certain plan views.
wevit
I have a problem in that certain section markers are not visible in plan views of most levels. As it happens all east-west setion markers are visible in all plan views within their range but north-south section markers can only be seen in plan view of one of the levels and in the perpendicular section views. The range of the sections extends through about 6 levels and the level where they are visible is not even the level the sections were drawn in.... edit: I have discovered that the section markers reappear when the plan view's scale is changed to 1:100 or 1:50 (unfortunately I need it to be at 1:200). At 1:500 or more ALL section markers disappear.. Post edited on 2005-12-14 23:11:14 Post edited on 2005-12-14 23:11:53
Wed, Dec 14, 2005 at 11:26:15 PM | RE: Sections lines not visible in certain plan views.
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Each section has a property for "hide at scales coarser than"... simply change it to what you need it to be.
Wed, Dec 14, 2005 at 11:30:15 PM | RE: Sections lines not visible in certain plan views.
wevit
Thanks! I had a feeling it would be something obvious..
building sections visible but detail view sections NOT visible on all drawings??
Tue, May 27, 2008 at 12:50:20 PM
Sections not visible in some views
Wed, Jan 27, 2016 at 11:40:20 AM
Linked Structural model not visible is certain rotated section views
Tue, Dec 22, 2015 at 2:27:12 PM
11
Model not visible in Ceiling Plan views
Wed, Jul 10, 2013 at 12:56:49 PM
disappearing grid lines
Wed, Apr 19, 2006 at 5:44:48 PM
Page generation time: 1.7380
