Forums >> Revit Building >> Technical Support >> Horizontal curtain walls
Fri, Feb 17, 2012 at 10:00:45 AM | Horizontal curtain walls
jonmcfarland
I have a soffit condition that uses the same panels as the curtainwall so I would like to use the same units that I've already created.
The question I have is: Can a curtain wall be created with its exterior face opposite of the floor beneath it?
 I've tried:
 Rotating a vertical CW - no luck
 Setting a vertical ref plane active and using that as the base for the wall - didn't work
 Creating a mass object and selecting a face for the wall by face - only the vertical faces were selectable
 Creating a mass object, changing a vertical face to a CW and then rotating the object so the CW was face down - wouldn't rotate
 Creating a mass object on a vertical ref plane, selected a horizontal face for the Wall by Face tool - received the message "Wall type 'Curtain Wall 1' is incompatible with picked face. Only basic wall types are accepted."
 Can I create the curtain wall that I'm trying to?
 Thanks,
 Jon
Tue, Feb 28, 2012 at 9:57:11 PM | Horizontal curtain walls
revitape
revitape Avatar
4.5 Stars: 9 Votes
Try Roof > Sloped Glazing
High quality modern Revit furniture!
www.therevitcollection.com
The Revit Collection: High Quality Revit Families | Revit Furniture
How to pin irregular (custom spaced) horizontal curtain wall grid
Wed, May 26, 2010 at 1:19:17 PM
Curtain walls: Different spacings between mullions.
Tue, Jun 2, 2015 at 9:46:09 AM
ACA Curtain Walls vs. Revit
Sun, May 4, 2008 at 8:20:27 PM
Angled Curtain Walls - fillets and nested
Thu, Apr 23, 2009 at 5:42:47 PM
Curtain walls
Mon, Nov 7, 2011 at 10:28:33 AM
Page generation time: 4.2505
