Forums >> Revit Building >> Technical Support >> space between ceiling and floor
Thu, Feb 16, 2012 at 11:18:26 PM | space between ceiling and floor
tarsamo
Hi everyone, I can see the back walls in the space between ceiling and floor in section. I don't want to see any of that, any recommendations?
Fri, Feb 17, 2012 at 7:47:38 AM | space between ceiling and floor
If your section depth includes this wall then why would you not want to see it?  Otherwise, decrease the depth of your section by pulling the far clip plane back.
Sat, Feb 18, 2012 at 3:46:30 AM | space between ceiling and floor
tarsamo
thanks, but What I mean is in the space between floor and ceiling in sections we usually see the rods holding the ceiling not columns and walls that are behind. If I do what you suggested it is going to affect the whole section and not just that space, any ideas?
space bounding
Wed, Mar 13, 2013 at 9:45:40 PM
First floor slab or ground floor ceiling?
Fri, Aug 30, 2013 at 7:41:03 AM
FLOOR / CEILING PROB WITH HOSTING LIGHT FITTINGS
Thu, Dec 15, 2005 at 10:30:38 PM
Inner space is not surrounded by outer space with higher height.
Thu, Sep 6, 2012 at 8:34:57 AM
ceiling tags - u/s of floor
Mon, Dec 21, 2009 at 2:42:06 PM
Page generation time: 0.9271
