Forums >> Revit Structure >> Technical Support >> Showing Load Bearing Walls from a lower Floor Plan
Thu, Feb 16, 2012 at 10:02:04 PM | Showing Load Bearing Walls from a lower Floor Plan
TzH09
Hello all,
The age old problem of showing load bearing walls on a first floor plan. Has anyone created a PAT. file (fill pattern) that is a grey fill colour with black diagonal lines?
I've successfully overlayed two wall plans, one with the diagonal hatch (transparent) and one with the solid fill, but this seems like a tedious work around. I found a hatch generator but that only allowed me to use lines and not a solid fill as well.
Does anyone else have alternative solutions?
Bearing vs. Non-bearing walls
Wed, Oct 10, 2012 at 3:04:30 PM
Load Bearing Walls hatched
Tue, Apr 13, 2010 at 7:18:55 AM
Walls not showing in plan region
Mon, Feb 18, 2008 at 1:59:12 PM
14
Cold Form Load Bearing ?
Thu, Mar 28, 2013 at 1:57:44 PM
Exterior Bearing Walls?
Tue, Jan 22, 2008 at 8:46:40 AM
Page generation time: 3.4168
