Forums >> Revit Systems >> Technical Support >> Rotating components, placing flanges, compentents are transparent - HELP
Thu, Feb 16, 2012 at 9:35:59 AM | Rotating components, placing flanges, compentents are transparent - HELP
vorasco
I have three questions... plelase help in anyway you can.
When I draw up a component and bring into my project file, I can rotate in one direction by not the other. I am in the proper view for the rotation direction I want but I get an error message telling me the component cannot be rotated. HELP?? It must be something with the way it was drawn but I cannot figure it out.
Next, when I try to place a flange on a pipe, I select the level I want the flange to be placed on. When I place the flange (Usually in the plan view) it will go anywhere but where I placed it plus it will go back to the default Level 1. It doesn't automatically connect to the pipe that I selected. HELP
Also when I bring components in they stay transparent. Is this always the case or is it something I'm doing when I am drawing the components up?
Please someone a little help here would be so greatly appreciated.
Thanks, Vivian
Thu, Feb 16, 2012 at 9:38:35 AM | Rotating components, placing flanges, compentents are transparent - HELP
vorasco
I should have said what version I am using, Revit MEP 2012.
space bar not rotating components
Tue, Jan 8, 2008 at 5:26:59 PM
Components not rotating with project
Fri, Feb 16, 2007 at 10:19:33 AM
RENDERING ISSUES- components become transparent.
Thu, Oct 18, 2007 at 8:03:01 AM
Rotating 3D Elements all at once
Thu, Dec 8, 2016 at 6:51:20 PM
12
2D diffuser transparency
Tue, Jan 7, 2014 at 12:17:10 PM
Page generation time: 0.1641
