Forums >> Revit Building >> Technical Support >> Help with Complex Massing and Curtain Walls
Sun, Feb 12, 2012 at 4:51:27 PM | Help with Complex Massing and Curtain Walls
designc
I am having trouble trying to add a simple curtain wall, on a complex mass. I first tried to bring this form from RHINO into Revit, but it seem to cut the form into pieces, rather than be two pieces or one piece. Then, I tried to make it in Revit, and it was pretty accurate. Once I started to divide the surface, it became so wonky! The only way it didn't look too wonky was to make it 80x80 pattern tile. I know people have done like twisted shapes and it typically works out...
Would you reccomend simplifying the shape? or addng less levels to make those types of grooves?
I am using Revit 2012.
complex massing
Thu, Jun 1, 2006 at 10:27:53 AM
curtain system by face in massing HELP
Fri, May 23, 2008 at 8:13:34 PM
Problems with Complex Curved Curtain Wall. Help!
Mon, Nov 14, 2011 at 10:08:54 PM
how can we make the curvy facade in revit 2013?
Thu, Dec 26, 2013 at 8:33:01 AM
in place massing problems
Thu, Jul 16, 2009 at 6:41:44 AM
Page generation time: 0.4403
