Forums >> Revit Building >> Technical Support >> two steps from hell
Fri, Feb 10, 2012 at 10:24:59 AM | two steps from hell
ramadon1369
i've tried a thousand and one different ways to model this stair! nothing works! i've ended up just extruding boxes to make the steps. I'd love any feedback on how to create this as an actual stair.
Fri, Feb 10, 2012 at 11:40:41 AM | two steps from hell
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
this was done rather quickly, so:
3D view  http://screencast.com/t/ajHjohrt
Use only the Boundary which is green line, and riser which is the black lines. to create the stairs you want.   http://screencast.com/t/mzcbygjH
Fri, Feb 10, 2012 at 2:29:38 PM | two steps from hell
ramadon1369
That's what I was doing, but it wasn't working. I saw that since you were able to do it, I must have had something wrong. Turns out the stair I wasn't using somehow doesn't allow that sort of configuration.  I soon as I switched my stair type, I got it to work. Thanks for your help!
Complete brick steps
Tue, Dec 31, 2019 at 11:06:46 AM
Revit 2017 What the Hell is an Incorrect Schema?
Fri, Aug 5, 2016 at 4:44:17 PM
Entryway steps
Mon, May 6, 2013 at 7:18:13 AM
what the hell
Mon, Jan 12, 2009 at 8:25:40 AM
Automatic steps numbering ?
Fri, Nov 4, 2005 at 5:12:31 PM
Page generation time: 2.0098
