25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> Wrapping Sweeps for Crown Mould
16 Posts No Rating |
Question for someone, I am adding Crown mould sweeps (see attached) and for some reason they are not "closing" on the ends of my walls. Even though I have done the modify feature (and making sure it is set to 90 degrees) and doing the little pencil feature it still does not join. Any help or advice would be appreciated, thanks. Dave
How are you doing these?
With Sweeps in the Edit Assembly of my duplicated wall type.
two solutions, either create the sweeps separate from the walls, or add a separate sweep not attached to the walls to fill in the gaps.
Wrapping sweeps at wall ends & corners? Any suggestions on how to? |
Tue, Dec 28, 2004 at 1:08:04 PM
How to add crown molding header above a window |
Thu, Feb 26, 2015 at 12:57:30 PM
Can you rotate wall sweeps? |
Wed, May 2, 2012 at 9:23:44 PM
Tag crown molding (wall sweeps) |
Thu, Mar 26, 2015 at 8:38:34 AM
Wall sweeps wrapping at ends? |
Thu, Jan 15, 2015 at 11:34:53 AM
