29 Users Online (27 Members):
Forums >> General Discussion >> Revit Project Management >> Pipe Auto-Route
I have added another piping system (Cast-Iron) in addition to the out of the box systems. I cannot find where in Revit 2010 the default settings are for the auto-route function. Could someone help me access this area so that I can add the new fittings to the pipe type.? - thank you
The error that I receive is that ," No auto-route solution was found.".
ok, I found the area where I can edit the fitting used for the type of pipe. It was under Type Properties. I now have the issue of getting eight bend for a sanitary system to be inputed as an elbow. Still receive the auto route error. Well I wonder if I can add new parameter for the Pipe Type. Anyone have input or better way to approach this? - Sorry, just kinda sharing my thoughts as I work through this issue.
No auto-route solution was found. |
Thu, May 26, 2011 at 7:55:07 AM
MEP |
Thu, Oct 29, 2009 at 8:17:05 PM
MEP QUERY - Sprinkler system showing route in angle |
Tue, Mar 3, 2009 at 10:02:18 PM
Trim HSS Round pipe into another HSS Round pipe |
Tue, Apr 3, 2012 at 4:39:45 AM
pipe dimensions |
Wed, Dec 2, 2015 at 7:47:03 AM
