18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Can I set default interior elevation view extents?
I am running through a two-story renovation project and have to do a lot of interior elevations. I create them no problem and drag the extents to the walls in plan, but when I open each view, the bottom view extent is always to the ceiling of the level below instead of the floor of the room I'm doing the elevation in. Is there a way to change this behavior so I don't have to drag each extent up every time I create a new one? Thanks.
29 Posts No Rating |
I am wondering the same thing. Any resolution to this?
0 Posts No Rating |
Has this ever been resolved?
Interior elevations typically extend to the 4 room bounding surfaces if Revit sees any. I think the problem you may be having is because you may not have a top room bounding element like a ceiling or floor set to room bounding.
.... or there is something else that is bounding this view.
If that is not your problem, I have seen models where this seems to have become corrupted but I could never find out why and I have never seen any good answers.
Edited on: Thu, May 29, 2014 at 8:12:20 AM
Elevation Extents |
Thu, Mar 5, 2015 at 6:56:31 PM
Revit 2013- Adjusting the default setting for Interior Elevation crop boundary? |
Mon, Aug 26, 2013 at 4:23:48 PM
elevation extents |
Thu, Jun 29, 2017 at 11:53:13 AM
Set default 3D view |
Tue, Feb 18, 2014 at 11:31:43 AM
view extents outside crop region |
Wed, Jan 5, 2011 at 12:13:56 PM
