Forums >> Revit Building >> Technical Support >> Plan View
Wed, Dec 14, 2005 at 3:15:35 AM | Plan View
cadjockey
Hi all, Even though a wall is made up a core and a finish layer can only the core layer be shown in plan view? eg. If I have a 190mm block wall with 14mm finish either side can the plan view show only the 190mm core and measure 190mm in plan view only? cadjockey
Wed, Dec 14, 2005 at 7:35:58 AM | RE: Plan View
jyothi
Set detail level as fine. Below graphics area there is one toolbar where u set scale of the drawing, control shade or hidden view etc there you have icon to set detail.change that level to fine. This should work. Regards,
Wed, Dec 14, 2005 at 4:47:35 PM | RE: Plan View
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
There is a workaround t do what your asking. So in plan you only want to show the core layers of the wall? At coarse scale you want see any of the layers but the wall would measure 218mm... Depending on your scale this may be still okay? Otherwise you'll need to set the view to medium detail level. Dimension to core layers to show 190mm then use override host layers in the view to make the finish layers appear as a white line (making sure there material has no cut pattern) this essentially makes them invisible... HTH.
Wed, Dec 14, 2005 at 9:18:29 PM | RE: Plan View
cadjockey
Hi, Mr Spot. Will setting up the drawing this way export to dwg the same way? Will the white lines show up? cadjockey
Wed, Dec 14, 2005 at 11:32:37 PM | RE: Plan View
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
It would depend on your layers file but most likely you'll end up with all the linework still in your dwg.
PLAN REGION VIEW DEPTH CHANGE OVERALL FLOOR PLAN
Fri, Aug 29, 2014 at 1:27:29 PM
Plan view levels
Tue, May 5, 2009 at 3:15:03 PM
PLAN REGION PROBLEM
Wed, Sep 10, 2014 at 11:15:22 AM
11
Beams showing above in plan view
Thu, Sep 4, 2008 at 11:18:12 AM
Sections not Showing in Plan View
Mon, Oct 28, 2019 at 4:42:02 PM
Page generation time: 0.8352
