Forums >> Revit Building >> Technical Support >> Component - Model in place - Lineweight
Thu, Feb 9, 2012 at 8:18:17 AM | Component - Model in place - Lineweight
JCArchitecture
Where do I change the Color and/or lineweight of the sketch lines for modeled in place components? We use these mostly for details and the default lines are much to heavy.
Thank you.
Thu, Feb 9, 2012 at 8:27:22 AM | Component - Model in place - Lineweight
When you are in any view, you can switch to thin lines under the view tab.  This makes all lines the same thickness on the screen only.  Model element lines are controlled under object styles.
Thu, Feb 9, 2012 at 9:32:22 AM | Component - Model in place - Lineweight
JCArchitecture
I know about the View > Thin Lines. I'm refering to Home > Component > Model in place. My lines in here by default are magenta. I see no settings/lines under Object Styles that are magenta. ???
Thu, Feb 9, 2012 at 9:48:20 AM | Component - Model in place - Lineweight
You asked :"...Color and/or lineweight of the sketch line..."  I answered for the lieweight.
Sketch lines are system controlled and I don't know of any way to change the color of sketch lines.
Fri, Feb 10, 2012 at 6:43:03 AM | Component - Model in place - Lineweight
JCArchitecture
O.K. So speciffically which one do I change to adjust the lineweight of the sketch lines?
Lineweight of In-Place Families
Thu, Apr 28, 2011 at 6:43:20 PM
Model in place component
Wed, Oct 11, 2017 at 11:46:05 AM
Profile uploading for model in-place component sweep
Sun, Oct 21, 2012 at 6:28:14 AM
Model-In-Place Component adhering to plan's view range.
Mon, Apr 12, 2010 at 12:18:43 PM
cant edit my model in place component [ 1 2 ]
Tue, Apr 12, 2022 at 3:08:17 AM
22
Page generation time: 5.7243
