Forums >> General Discussion >> Revit Project Management >> Revit MEP pipe diameter difference
Thu, Feb 9, 2012 at 2:17:05 AM | Revit MEP pipe diameter difference
Vpokunoff
Hey Revit Community,
Could somebody explain me about the pipe outer diameter difference from standard diameter.
When there is a pipe diameter with 65 mm. Then outer diameter value is 63.5 mm.
What is the difference and where is 1.5 mm?
Thanks
Poku
Thu, Feb 9, 2012 at 11:01:35 AM | Revit MEP pipe diameter difference
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I believe the system uses standard pipe sizes. Similar to the listed here. http://en.wikipedia.org/wiki/Nominal_Pipe_Size
Fri, Feb 10, 2012 at 6:12:21 AM | Revit MEP pipe diameter difference
Vpokunoff
Thx for the answer.
I was really confused by this. Im not an engineer but it just seemed little bit wrong.
Mon, Feb 13, 2012 at 10:32:46 AM | Revit MEP pipe diameter difference
dharris0018
Sounds like one system is using soft metic and another hard metric.
REVIT MEP
Sun, Aug 23, 2009 at 2:57:44 PM
Revit 2012 MEP pipe sizes
Tue, Mar 6, 2012 at 2:13:57 PM
Routing Preferences - Pipe MEP
Thu, Oct 18, 2012 at 6:49:10 PM
pipe annotation tolerance
Thu, Jan 2, 2020 at 2:21:35 PM
Outside Diameter vs. Nominal Diameter
Tue, Jul 29, 2014 at 8:30:33 PM
Page generation time: 1.8573
