Forums >> Revit Building >> Technical Support >> Print Error "Display Error"
Tue, Dec 13, 2005 at 11:39:52 PM | Print Error "Display Error"
skwwr
After renaming a couple of Revit files. I was unable to print from any of the files. I get the error while printing a 1/2 print. "Display Error An error has occurred while drawing the contents of this window. This window shall be closed." Then Revit quits and I only get a portion of my print. Any ideas to fix it?
Wed, Dec 14, 2005 at 2:00:48 AM | RE: Print Error "Display Error"
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Turn off open GL, or simply close some of the views. Long term fix, update your display card driver.
Tue, Dec 20, 2005 at 2:09:44 PM | RE: Print Error "Display Error"
skwwr
I do not think it is a driver error. Because I have been able to print half size sheets on other Revit Drawings...I only get ther error on the drawings I renamed
Tue, Dec 20, 2005 at 5:04:34 PM | RE: Print Error "Display Error"
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Yes it is. Its caused by either the Open GL or overlay planes settings or a combination of the two not liking your video card drivers OR having too many views open at once.
A Serious Error [ 1 2 ]
Thu, Jul 26, 2007 at 11:41:07 AM
21
Opening 2008 file in 2009 causes "Unrecoverable error" crash
Tue, Jul 28, 2009 at 1:36:33 AM
"error while drawing contents of this window" error. What is causing it?
Mon, Aug 25, 2008 at 5:58:47 PM
12
Revit "appcrash" error
Tue, May 25, 2010 at 2:48:11 PM
Error Message
Wed, Oct 10, 2007 at 11:13:58 AM
Page generation time: 2.4783
