17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> showing angular dimensions in degrees seconds etc
24 Posts No Rating |
Can anyone help me with angular dimension formatting? I can't seem to change from decimal degrees to degrees minutes seconds. When I look at Project Units under settings, the angular format checkbox is always greyed out. I can't find anywhere to change that setting.
Thanks for any assistance..
Karen
admin
I took a look at it and seem to have the same problem you're having... sorry that's not much help is it!
Hiroshi Jacobs
The Catholic University of America |
This option is currently not supported by revit unless it is a site line in which case you can label these using site annotation. I have spoken with Autodesk and a request for this ability has been filed.
Cheers,
Chris.
Regards,
Chris.
Thanks Hiroshi for taking a look at it, and thanks Chris for filing with Autodesk! I was thinking I was missing something very simple right before my eyes....
Karen
angular dimensions more than 180 degree?? |
Sat, Apr 25, 2009 at 7:09:21 AM
Showing doors at 45 degrees |
Thu, Apr 17, 2008 at 8:05:54 PM
Degrees symbol |
Wed, Nov 23, 2005 at 12:33:00 AM
Revit Base and Survey Point Long & Lat Format |
Wed, Jun 13, 2018 at 11:14:42 AM
Angular surfaces |
Fri, Oct 16, 2009 at 2:23:30 PM
