18 Users Online (16 Members):
Forums >> General Discussion >> Wishlist >> View range
21 Posts No Rating |
Walls with base extensions don't appear to clean up at joints when the view depth on the plan view range is set below the base of the wall.
Plan view range works very strangely sometimes . . .
Actually clean ups of joints don't work terribly well for dissimilar walls, especially where there are differing numbers / orders of wall layers. Would be good to be able to select the individual layers at ends of walls and drag to abut adjacent wall layers at the desired intersection (similar to adjusting wall hatching alignment), instead of the limited options guessed at by the "Edit wall joins" command.
C
Post edited on 2005-12-13 21:37:27
view range |
Fri, Sep 7, 2007 at 2:28:04 AM
View Range |
Tue, Aug 28, 2007 at 9:52:27 AM
View Range for Revit Link |
Thu, Nov 12, 2015 at 7:10:18 AM
low wall not displaying correctly with view range |
Fri, Aug 3, 2012 at 4:35:37 PM
In place families above the view range are still appearing |
Tue, Dec 23, 2014 at 9:17:05 AM
