Forums >> Revit Structure >> Technical Support >> Counting in the schedules
Tue, Feb 7, 2012 at 11:57:39 AM | Counting in the schedules
ddenton85
Has anyone figured out a work around for using the Count in a formula in the Schedules. I am trying to take a stud count and multiply it by a waste percentage to get a more realistic number for our stud order. Any insight is greatly appreciated. I know this has been on the wishlist for quite some time.
Wed, Feb 8, 2012 at 8:22:57 AM | Counting in the schedules
mansell5
3.5 Stars: 4 Votes
hello ddenton.
stud count = length/ stud spacing.
what about reducing stud spacing by the waste increment you wish to add.
ie if stud spacing is 600mm or .6m, and you want  5% waste, reduce the 600mm spacing by 5% to increase the count.
using 5% as waste, the spacing would be 570 instead of 600  (600*5/100=30).
so in a 5m run of studs with no waste  and studs at 600ctrs there would be 8.33 + 1 studs(start of run)=9.33 rounding = 9 studs
the same with 5% waste would be 8.77 studs + 1 = 9.77 . rounded up = 10 studs
cheers mate.
Wed, Feb 8, 2012 at 8:26:14 AM | Counting in the schedules
I would think you just add a calculated field, a seperate column that performs this for each wall, then totals.
Wed, Feb 8, 2012 at 9:18:54 AM | Counting in the schedules
ddenton85
I am using an addin that populates my walls with studs, top plates, base plates, and frames out my openings and creates custom stud configurations for wall intersections. My studs are acctually there and not just a result of a formula. I suppose this might make what I am doing a little more difficult, but I do get a very accurate number. I can show the customer this number no problem. We just want to be able to show them everything we can, including waste.
Fri, May 18, 2012 at 1:23:01 PM | Counting in the schedules
rfisher218
What program are you using?  We are currently trying to find a better way to calculate studs.  Our project manager as been using a Length/9" but my boss swears thats too much.  I'm the guy with the job of finding a better way...
walkthrough counting numbers on the right top of the image
Fri, Sep 12, 2008 at 6:31:39 PM
Revit double counting objects in Schedule
Mon, Apr 13, 2009 at 1:58:19 PM
Coloring an area, without coloring my furniture?
Thu, Nov 8, 2012 at 8:43:50 AM
Nested Door Families and Door Schedules
Mon, Nov 8, 2010 at 2:56:46 PM
Counting
Sun, Mar 2, 2008 at 8:01:50 PM
Page generation time: 0.1026
