Forums >> Revit Building >> Technical Support >> Ballusters Panels don't fit railings. Attached pictures
Tue, Feb 7, 2012 at 4:21:59 AM | Ballusters Panels don't fit railings. Attached pictures
keeza09
I am using Revit Architecture 2011 and I am trying to set up a railing for a set of stairs, however the panels aren't quite working how I would like. I am trying to use 1000mm panels for the bulk, however, I would like to fit an appropriate panel size where a 1000mm panel won't fit, obviously, eg. toward the end of the rails or on the small horizontal rails.
For a clearer idea of the problem, I have attached a picture of the stairs and also the 'EDIT TYPE' > 'BALLUSTER PLACEMENT' window. As you can see in the picture of the stairs, I am trying to fit panels to the rail for the stairs (for which I created a ramp as well as the stairs and then hid the ramp, leaving the stairs and the rail for the ramp) and the smaller horizontal panels section.
Thanks in advance for any answers!
Kieran
Thu, Feb 9, 2012 at 8:08:55 AM | Ballusters Panels don't fit railings. Attached pictures
keeza09
bump
Thu, Feb 9, 2012 at 8:24:54 AM | Ballusters Panels don't fit railings. Attached pictures
Tom Dormer posted elsewhere (similar threads):
"I suggest downloading the most definitive guide on stairs from Phil Read.
http://dl.dropbox.com/u/125962/AB114-1.pdf
Phil worked for Revit before purchased by Autodesk and continued to work for Autodesk for a number of years.  He is also co-author of the new Mastering Revit book.
His blog: http://www.architecture-tech.com/  "
Railings - How to spread to fit glass panel balustrades?
Wed, Aug 19, 2009 at 6:24:01 PM
How to bend my workplane to fit curtain surface... ?
Tue, Feb 24, 2009 at 8:05:40 AM
My railings doesn't go with my stairs
Mon, Dec 2, 2013 at 11:45:03 AM
13
GRILLWORK TO FIT ARCHWAYS ON PORCHES
Wed, May 9, 2012 at 3:50:33 PM
Glass Railing
Wed, May 5, 2010 at 3:11:19 PM
Page generation time: 2.9816
