Forums >> Revit Structure >> Technical Support >> "Referenced From" Issue with Section Marks
Mon, Feb 6, 2012 at 2:25:24 PM | "Referenced From" Issue with Section Marks
Vigoren
My firm is new to Revit. In AutoCAD we go with the 2 part section mark, with both the "referenced from" and "detail location" sheet numbers. We typically do large scale building sections with break lines, rather than small scale sections and call out details.
Anyways, my problem is that the "referenced from" portion of the building section marks only ever returns "S1.1", regardless of what page the plan is actually on. I've got plans with the section marks on each of S1.1, S2.1, S3.1, and S4.1. The section marks should be returning the corresponding page number, rather than just the first page.
The second part of the problem (and undoubtedly the same issue) is that the view port title for the building section also only returns "S1.1" for the "referenced from" field. This should be returning ALL 4 page numbers, as the section was referenced from those 4 pages.
If anyone has any advice on how to make this work properly, I would appreciate it. Even a good "cheat" would be nice. About all I can think of is putting a masking region over the text and manually inputing new text over it.
Mon, Feb 6, 2012 at 2:55:01 PM | "Referenced From" Issue with Section Marks
Sorry - others have asked for this and Revit doesn't do it.
You will have to do what you did in CAD for all of the referenced views.
Section marks w/ SIM
Thu, Feb 23, 2017 at 12:37:36 PM
14
Revit 2012 - material tag "question marks" everywhere
Wed, Sep 13, 2017 at 9:26:13 PM
13
section marks
Tue, May 17, 2005 at 12:54:13 AM
Section marks appearing on plans
Thu, Dec 6, 2012 at 4:26:26 AM
Duplicate Marks on Door Tags
Thu, Dec 4, 2014 at 2:08:04 AM
Page generation time: 1.1771
