Forums >> Revit Building >> Technical Support >> Spot Elevation Override
Mon, Feb 6, 2012 at 2:13:44 PM | Spot Elevation Override
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I want to be able to use the spot elevation in instances where the elevation might need to be "faked" a bit.  Is there a way to override the actual elevation numbers like you can with dimensions to replace it with what I want it to say with either numbers or text?
Mon, Feb 6, 2012 at 2:24:01 PM | Spot Elevation Override
Bad ....bad...BAD! ...
I hear you....
I don't believe there are any over-rides available but you can:
  1. Set up different spot elevations with different units (rounding )
  2. Create a fake spot elevation family
  3. Add a small 3D line in the proper place and elevate that.
Mon, Feb 6, 2012 at 2:55:37 PM | Spot Elevation Override
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Yea not good I know but sometimes its just easier.  What do you mean by create a fake spot elevation?  Itd be nice to be able to add text to the spot elevation instead of the numbers.
Mon, Feb 6, 2012 at 3:00:03 PM | Spot Elevation Override
Just edit your spot elevation tag - remove the parameter that reads the elevation and add an instance text parameter, then save under a different name and load it in your ptoject.
Tue, Feb 7, 2012 at 9:01:35 AM | Spot Elevation Override
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
So I fooled with this a bit yesterday and I couldnt figure it out.  The spot elevation is a system family (hard to find at first) but when I found it and opened the file under the RAC 2012\Libraries\US Imperial\Spot Elevation- Target Filled to modify it all that is there is the target head and filled region.. not text or parameters.  I'm assuming that I am looking in the wrong spot, could you point me to the correct location if I am?
Tue, Feb 7, 2012 at 10:44:57 AM | Spot Elevation Override
Sorry, I forgot that was system.  You will have to make a unique symbol that still uses your cross hairs.
Mon, Oct 5, 2015 at 7:14:28 PM | Spot Elevation Override
mike3
Was there ever a solution to this?
Tue, Mar 5, 2024 at 7:26:45 PM | Spot Elevation Override
Ridation
18 years later... nothing yet
Spot Elevation vs. Level elevation
Tue, Aug 19, 2025 at 1:06:15 AM
Invert Elevation Vs. Spot Elevation
Mon, Apr 20, 2015 at 2:09:11 PM
Spot Elevation without Target
Fri, Mar 20, 2009 at 4:57:55 PM
Spot elevation tag issue
Mon, Jun 3, 2019 at 3:18:37 PM
Elevation Level Override
Thu, Apr 5, 2018 at 1:22:35 PM
Page generation time: 1.2194
