27 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> Room not showing
1 Posts No Rating |
Hi,
I'm using Revit 2011. I've a issue with a room. The room exists and is shown in all views but in the one I need. Therefore I can not even place a tag for it.
All other rooms are seen in every view.
The view properties are the same for each view and the room properties as well.
I checked worksets, hidden objects, separation lines, visibility filters, and everything seems alright.
I attach the view of two different rooms of the same level, one showing and on not showing the room.
Did anyone have the same problem?Thanks!
There are too many possibilities for what is wrong here.
The easiest solution is to create a new view and see if you can tag it there. If so, you can copy, paste same place, all 2D elements to this new view and delete the old.
yes
Room names Not showing in Schedule [ 1 2 ] |
Tue, Jul 24, 2012 at 7:05:38 AM
20
Room tag not showing in only one room. [ 1 2 ] |
Sat, Sep 27, 2025 at 3:40:00 AM
15
color fill scheme showing up in entire building except one room. |
Thu, Jan 16, 2014 at 9:45:17 AM
Room finish Schedule showing Deleted Rooms |
Wed, Aug 26, 2009 at 3:56:37 PM
ROOM AREA VARIES DEPENDING ON THE DISTANCE FROM PROJECT ORIGIN |
Thu, Jul 12, 2012 at 8:24:17 AM
