Forums >> General Discussion >> Revit Project Management >> Symbols in Revit
Sun, Feb 5, 2012 at 5:55:09 PM | Symbols in Revit
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
Is it just me or do you really have to do Alt + 0186 for the degree symbol or is there a proper way....
Even AutoCAD had symbols built in.
Edited on: Sun, Feb 5, 2012 at 5:55:39 PM
Revit 2018........
Mon, Feb 6, 2012 at 7:42:21 AM | Symbols in Revit
Revit uses TrueType Fonts that are available to all programs.  AutoCAD uses SHX files which were only written for AutoCAD.  Whether or not the degree symbol is available in your font style is dependent on the font.
Goto your windows start and select run ... type in CHARMAP  ... this program will show all the special keys available for whichever TTF you are using and you can select the item(s) - copy it to your clipboard and ctr'l V paste it into your revit text.
Mon, Feb 6, 2012 at 7:05:09 PM | Symbols in Revit
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
ohhh I see. Thanks for the CHARMAP helps alot saves me googling things I need. Thanks again WW.
Revit 2018........
symbols, detail components
Mon, Jan 23, 2012 at 6:35:40 AM
Deleting import symbols
Thu, May 8, 2008 at 3:14:21 PM
Electrical symbols - scaling
Tue, Feb 5, 2013 at 7:18:56 AM
Symbols in Legend won't print
Sat, Nov 28, 2015 at 7:30:06 PM
14
SYMBOLS
Fri, Mar 6, 2009 at 11:02:48 AM
Page generation time: 1.9474
