Forums >> Revit Building >> Technical Support >> Creating different Masonry walls with different finishes
Sat, Feb 4, 2012 at 2:37:16 PM | Creating different Masonry walls with different finishes
MongooseST1
MongooseST1 Avatar
I have created various masonry walls each with their own finishes on the outside and inside using the EDIT TYPE then editing the STRUCTURE by defining the surfaces exterior and interior with their respective finishes. I create a masonry wall by duplicating it then changing the name and finish settings to create that particular wall. When I do this for my four different walls ALL the walls have the finsihes pertaining to the last one created and edited. There is something I am missing in a big way. Can anyone help me?
Thanks in Advance
Sat, Feb 4, 2012 at 9:07:02 PM | Creating different Masonry walls with different finishes
Warchitect
4 Stars: 5 Votes
you might need to define new seperate materials too. try creating a copy of a material that you want to change, change it, and see if that works.
masonry walls?
Tue, Jun 22, 2010 at 5:35:51 PM
concrete wall and masonry wall to have different lineweights
Thu, Jan 6, 2011 at 12:39:04 PM
Curved Masonry Walls
Thu, Dec 13, 2007 at 12:17:27 PM
Creating a wall finishes schedule, and coding wall finishes on elevations
Fri, Jun 1, 2012 at 4:06:32 PM
Splitting wall finishes
Thu, Apr 6, 2006 at 8:36:14 PM
Page generation time: 0.7806
