Forums >> Revit Building >> Technical Support >> hosting uplights to ramps
Fri, Feb 3, 2012 at 6:09:06 PM | hosting uplights to ramps
ccranbou
I'm trying to place floor-based uplights on a ramp -- Under edit family for the light fixture file I've unchecked "always vertical", but it still wants to attach to the floor below the ramp and I can't rotate the lamps so they're parallel to the ramp plane.
I'm using Revit 2012.
Thank you,
Fri, Feb 3, 2012 at 6:39:29 PM | hosting uplights to ramps
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
use face based instead of floor based
Fri, Feb 3, 2012 at 7:26:28 PM | hosting uplights to ramps
ccranbou
Thanks, there doesn't seem to be very many options as far as faced-based uplights go unfortunately... I haven't been able to find what I'm looking for: simple LED uplights that recess into the floor.
Linear uplights don't seem to be working.
Thu, Jun 25, 2009 at 10:19:26 AM
Hosting a Sweep Mass element
Mon, Aug 17, 2009 at 7:06:22 AM
Attach Walls to Ramps
Fri, Feb 18, 2011 at 6:45:16 AM
Showing break lines with Ramps and Stairs
Mon, Jul 30, 2018 at 11:02:36 AM
TYPE SELECTOR for ramps and stairs
Thu, May 3, 2007 at 2:46:53 AM
Page generation time: 0.0245
