11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Modifying Mass - Moving edge creats curve instead of angles/facets.
4 Posts No Rating |
I'm using Revit Architecture 2011. I'm somewhat new to massing. When I creat an in-place mass, I add edges to my extrusion and then "pull" them. The result is a curved form. I want to maintain angled faces, NOT a curve. Can this be done somehow?
Edited on: Fri, Feb 10, 2012 at 10:31:21 AM
16 Posts No Rating |
Hi I have exact the same requirement. I tried adding a profile in a extrusion. After adding when I tried to drag a corner the completed form is bending in curve where I want it in straight. Is it possible???
Atleast some one say it is not possible...as an alternative I tried using blend adding another profile in between but still that doesn't show exact output. Any suggestions???
Faceteted Aphitheatre Conceptual Mass |
Fri, Sep 15, 2017 at 11:47:37 AM
Roof - Extrusion Along path - Conceptual Mass - 3D curve |
Thu, Apr 25, 2013 at 1:47:26 PM
12
Concrete Slab Edge Angles |
Wed, Dec 7, 2011 at 12:35:24 PM
13
Need help in modifying |
Mon, Dec 10, 2007 at 3:37:32 PM
curve Curtain grid |
Thu, Apr 2, 2009 at 10:54:57 AM
