11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Ramp / slab clean up at intersection
21 Posts No Rating |
Has anyone managed to get a sloping slab or ramp of the same width as a floor slab to clean up / mitre at the intersection without resorting to creating other geometry to subtract / join to each?
C
If they are both floors then just use join geometry and that should clean it up.
If its a ramp then you won't be able to cleanup neatly as you cannot join anything to a ramp. Best result would be to place a floor slab edge where you want the slab/ramp to join to make them look as though they merge and then use the linework tool to remove excess linework.
Otherwise its probably easiest with an in-place floor family.
HTH.
Join geometry didn't clean - is a one off so was easiest to do in place floor family.
Thanks Mr Spot
They need to be the same material for the linework to remove completely.
A ramp! |
Thu, Jan 21, 2016 at 11:37:45 AM
Wall intersection issue |
Thu, Nov 26, 2015 at 9:26:18 AM
Can you slope a ramp side to side? |
Thu, Mar 4, 2010 at 10:12:17 AM
RAMP TAG FAMILY FOR RAMP NAME |
Mon, May 9, 2016 at 6:49:09 AM
walls overlap but dont join. |
Sat, Jul 30, 2016 at 5:13:58 PM
