Forums >> Revit Building >> Technical Support >> Stair Winder issue
Thu, Feb 2, 2012 at 11:25:21 AM | Stair Winder issue
RNLRNL
I think I posted this early by mistake
See attached image. When I craete a stair with a corner angled riser the stairs only forms if the risers are sufficiently far apart. In the attached image you will see the left hand corner stair is formed beacuse teh risers are set of from the corner riser but then there is a gap where the next landing junction stair should be because the risers are closer to teh corner - any idea why this is and how to get round it.
I often want to do a corner angled riser and always encounter the same problem.
Any help would be appreciated.
Thu, Feb 2, 2012 at 11:57:03 AM | Stair Winder issue
Post your stair sketch image....
Thu, Feb 2, 2012 at 2:13:51 PM | Stair Winder issue
RNLRNL
Attached is the stair sketch
Thu, Feb 2, 2012 at 2:15:41 PM | Stair Winder issue
RNLRNL
Note the right side of the sketch where the risers are further apart forms properly in the 3d image but teh left side where the risers are closer doesn't form.
Any ideas
Thu, Feb 2, 2012 at 3:08:18 PM | Stair Winder issue
You are sketching boundry lines and risers, correct?  You need breaks in the boundry line as appropriate at winders.  Experiment with that while having a tiled 3D view so you can see what happens.
Thu, Feb 9, 2012 at 8:10:57 AM | Stair Winder issue
That project file you posted was corrupt so I deleted the post.
Thu, Feb 9, 2012 at 8:19:43 AM | Stair Winder issue
Watch this: http://www.youtube.com/watch?v=FtqcRuVkG2k
Thu, Feb 9, 2012 at 8:43:59 AM | Stair Winder issue
RNLRNL
I watched the tutorial but it didn't help. The issue is that the strair itself (maybe because it is monolithic) doesn't seem to be able to form whne there are closely located risers.
If I sent a thickness for the treads than all the treads appear ocrrectly - even though the stair itself below doesn't appear.
I have resaved and attached the file - hopefully you will be able to open in.
Thanks
Thu, Feb 9, 2012 at 8:45:32 AM | Stair Winder issue
RNLRNL
sorry - attached now
Thu, Feb 9, 2012 at 8:50:07 AM | Stair Winder issue
RNLRNL
I am also attaching a jpeg showing the tread forming correctly on the winder but no actual stair forming below
Thu, Feb 9, 2012 at 9:52:22 AM | Stair Winder issue
#11
It looks like I have never done a winder monolithic stair..... Seems there is a problem here.  I would send this issue to AutoDESK.  In the meantime, I would simply model this as three runs and individual slabs for the winders.
Thu, Feb 9, 2012 at 5:31:14 PM | Stair Winder issue
#12
RNLRNL
ok. thanks for you help.
Is there a specific AutoDesk address to send this to?
Do they normally reply or have some formof solution?
Winder Stairs in 2013
Tue, May 8, 2012 at 12:49:31 PM
How to achieve newell posts on winder stair
Tue, Jul 24, 2007 at 6:18:30 AM
partial wall miter below winder [ 1 2 ]
Sun, May 3, 2009 at 12:21:40 PM
20
Monolithic winder stair
Thu, Aug 22, 2013 at 12:50:18 PM
stair with 2 winder -> railing
Wed, Sep 9, 2009 at 12:38:00 PM
Page generation time: 0.3821
