10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> Simple roof problem
Hey guys just a quick question. As you can see I have joined two roofs together but when I do fascia and gutter it goes
all the way through when it souldnt and doesnt join the gutters. I have tried changing the larger roofs outline to break it
but when I do that it says it can't join the roofs.
http://screencast.com/t/pSlUuvmOmu
http://screencast.com/t/AcscRXVI
Revit 2018........ |
easiest solution would be to build that as one roof.
When I do that then the ridge is wrong thats all.
also is there a way to demolish part of a roof like if I was doing an extension I usually just demolish the whole roof and
do the whole thing as new.
Edited on: Wed, Feb 1, 2012 at 6:18:53 PM
Fascia and gutters have grips like in CAD. IF you meet two perpendicular grips the geometry will join. You can use voids to demo sections of roof. Sometimes with roofs like that I will draw model lines where the valley is and change the sketch lines to follow the valleys.
http://www.turbosquid.com/Search/Artists/Revitaoist |
As alterego says ... do this as one roof. That is the better solution then using the grips. Here is a post that shows you a similar roof and how you can do it without having the ridge problem you speak of. Look at my post in this thread.
http://www.revitcity.com/forums.php?action=viewthread&thread_id=26504
Thanks guys now all works....what would I do without revit city
Roof join/void form problem |
Wed, Aug 14, 2024 at 4:51:22 PM
Roof layers not alligned |
Tue, Aug 31, 2010 at 2:07:38 PM
Roof problems! |
Sun, Feb 1, 2004 at 7:26:42 PM
Cannot do a Vertical Opening in a simple roof |
Thu, Jan 21, 2010 at 2:02:37 PM
roof deck simple ? |
Thu, Jan 19, 2012 at 1:18:02 PM
