Forums >> Revit Building >> Technical Support >> Stair railing at extension in Revit 2012
Wed, Feb 1, 2012 at 10:23:50 AM | Stair railing at extension in Revit 2012
erickson1026
Hello,
I have searched around and can't quite find a resolution to the attached pdf.  I have built a custom baluster for the extensions, but the diagonal rail and top extension don't meet.  Any tips would be most appreciated.
Revit 2012
Thanks!
Wed, Feb 1, 2012 at 10:34:58 AM | Stair railing at extension in Revit 2012
erickson1026
Nevermind I got it.  I had the rail path too long...brought to the start of the first riser and it worked out.
Wed, Feb 1, 2012 at 10:38:36 AM | Stair railing at extension in Revit 2012
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
good
Edited on: Wed, Feb 1, 2012 at 10:39:02 AM
Wed, Feb 1, 2012 at 11:53:40 AM | Stair railing at extension in Revit 2012
CDWdavid
5 Stars: 5 Votes
Do you really want to place the railing post at the edge of the nosing?
The way I did was to create two extensions, one for top one for bottom.
Wed, Feb 1, 2012 at 12:11:10 PM | Stair railing at extension in Revit 2012
Actually, you don't have to do that.  If you break your railing sketch line at the point where the railing will break from soped to flat, and assign the flat area of the sketch to flat, you can move that post.  The only problem is the railing change of angle will be a miter and not a gentle curve.
Stair railing baluster falls short on ADA railing extension
Mon, Feb 8, 2016 at 7:38:52 PM
Railing Extension Problem
Mon, Dec 5, 2016 at 12:52:29 PM
Handrail Extension at Top of Stair
Thu, Jul 2, 2020 at 6:50:20 AM
12" RAILING extension (Image Attached)
Sat, Aug 30, 2008 at 9:53:18 PM
Add railing to existing stair
Tue, Oct 29, 2013 at 7:49:39 PM
Page generation time: 1.4765
