16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Phasing - showing all phases in a view
13 Posts No Rating |
I am working on a project that will have existing construction, demolition, and new construction. The issue I am having is that in the properties window only allows me to show either existing or new construction, not both at the same time in the same view. We will be doing some renderings and I've noticed that when I render if a phase is inactive it wont render correctly. I am working in Revit Architecture 2012
If your view, phase properties is set to new and the phase filter is set to show all, then you will see everything. But if the view phase is set to existing, then you will not see the new when show all is selected.
phasing |
Fri, Oct 7, 2005 at 8:14:02 AM
Showing multiple phases in one viewport |
Tue, Jun 16, 2009 at 8:02:56 PM
Phasing Setup |
Tue, May 15, 2012 at 1:29:05 PM
12
is it possible to disable phasing Graphic Override on a view |
Thu, Jun 8, 2017 at 3:34:46 PM
Phasing: creating 3 phases, filter out middle |
Thu, Jan 22, 2015 at 9:02:29 AM
