Forums >> Revit Building >> Technical Support >> How to subdivide the Building in Revit?
Wed, Feb 1, 2012 at 5:58:23 AM | How to subdivide the Building in Revit?
habib455
I want to subdivide my Revit building model including its components in many segments. These segments will be carried out one after another in the reality. How can I do that without need to subdivide every component (walls, ceilings....) ?
Wed, Feb 1, 2012 at 7:56:53 AM | How to subdivide the Building in Revit?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Are you doing this for construction purpose?  It sounds as though you are talking about phasing.. if you are this link may be useful
http://wikihelp.autodesk.com/Revit/enu/Community/Examples/Example_Project_to_Illustrate_Phasing
Wed, Feb 1, 2012 at 10:00:54 AM | How to subdivide the Building in Revit?
habib455
thanks,
but i m not talking about phases. I have a Revit-Building- Model and I want to divide it in Cryingcast concrete - zones).
Wed, Feb 1, 2012 at 10:14:35 AM | How to subdivide the Building in Revit?
It sounds like your looking for 4D BIM.  Sequencing the portions of your model.  You can do this in Revit but it does take extra work.  I believe NavisWorks may do this better but we don't use it.
Search the web for 4D BIM to learn more about how others may be doing this.
Wed, Feb 1, 2012 at 11:01:23 AM | How to subdivide the Building in Revit?
habib455
thanks a lot
Masses With Surface subdivide using adaptive component - keeping it speedy?
Thu, Dec 20, 2012 at 1:48:13 PM
panel walls - getting walls to subdivide automatically with joints already in.
Wed, Nov 24, 2010 at 6:22:27 PM
Moving a Building
Wed, Apr 30, 2008 at 5:49:59 AM
Problem: How to cut building into landscape
Fri, Apr 1, 2011 at 3:02:59 PM
WHY THE A.REVIT BUILDING GOES SOOO SLOW?
Fri, May 4, 2007 at 2:43:19 AM
Page generation time: 1.4608
